I’m thinking in what would be the pro and the cons of creating in DB a generic element instead of a specific one. I’m thinking about scaling the app in future, and trying to start as neat as possible.
Can you friends share a little insight? Please see the example:
Generic
Item element, has a yes/no field for positive/negative
Specific
Create a positive item
Create a negative item
With thousands of users, would it be there any advantage in processing power, disk read/write or app responsiveness if you do a search for a specific “positive” item instead of a item with a “yes” constrain?
If the item value is not fixed (can change yes to know under some rules), I think the only way is to go generic.
