Hi, community
I don’t know where to find the solution anymore.
These are tabs in GroupFocus. They do not stay in the determined position. When I generate a preview they always appear displaced.
There are elements underneath, perhaps this could be causing the problem. I already had a bug situation caused this way.
In the editor, the tab is perfectly positioned, referenced to the “Painel” element.
But, when the preview is generated, the tab appears moved to bottom.
Does anyone have any tips on what I could try?
