Right now, two random integers (which can be the same integer) are chosen from an app data list and the two rows of buttons are generated to include those integers and some incorrect ones.
When the user presses submit, the two values currently selected update two fields of the current user. My question is how to compare the two values of those two fields with the two values that are IntA and IntB? The two sets of numbers need to match exactly, but do not have to be in the same order.
there’s not enough information here to determine how you’re currently going about what you’re doing and why you can’t just do a conditional of “when number A is number B…” My guess is that you need to set states of an element to hold the values in and then use a conditional to compare them. Or use a “when condition is true…” event.
Thanks, that was actually enough to get me going in the right direction. I’m so fresh that just basic things like realizing how to use states doesn’t occur to me.
