Help ! Problem with the input number
Hello, I would like to know why the phone numbers do not display 0 at the beginning? I use an input in number format (integer)
Phone numbers should ‘text’ not numbers.
Hi, thx ! Could you tell me what the data type (text or number) and the input should be (text(numbers only) or text or…?)
Anything that evaluates to a text will work…
So it depends on exactly what you want to allow users to input…
But most likely Text (numbers only) will be what you’ll want to use for a phone number unlit.
Thank you it worked
