Hello, im new here, this is my first project. Im trying to show contents on a repeating group using two dopdown elements. i need when press the Dropdown A the Dropdown B must reset to the placeholdder, the same on reverse
I don’t think you can achieve this using Bubble’s pre-built dropdowns. You would need to build custom dropdowns instead using a Group + a Focus Group for each one. See a quick example here:
