Help with Collapsing Groups
Hi bubblers,
Please help with this problem I have.
I have two groups. Group A and Group B.
I have group A same shape and size with B.
Both A and B have repeating group inside of them.
Group B is some pixels below Group A.
I have set the collapse when hidden for both groups.
When I preview my app, it hides as it should be but the space remains there.
Group B does not move up to fill the space.
Please what can I do?
See fourm_app link
i have a collapse here, https://bubble.io/page?type=page&name=scroll2&id=niceapp&tab=tabs-1 if you want to check it out.
Thanks @anon65040322. Please check the forum app link
Your conditions are not set right,
this is why its not collapsing.
You should name your repeating-group’s parent collapsable group:
something like ‘Collapsable Rg SalesPeople’
Thanks for the help. I just changed the condition now, Still no luck.
idk its acting weird, try on one of your own apps.
Hi @bosunjohnson :slight_smile: This is happening because there is a hidden, alert element that overlaps with the Group A element:
If you set the alert to be positioned at the top of the page, this should cause everything to collapse correctly:
Thanks a lot. You’re the best! :grinning:
No problem at all, @bosunjohnson! :smiley:
