I have a management page which has a list of events for the person who owns/manages said events. The list displays certain attributes such as date and style. I have a popup that notifies the owner, when the page loads, if dates and/or styles are missing from the events, and from this page the dates and styles can be added and/or modified.
I created a workflow such that when the page loads, the popup is opened if any of the dates or styles are empty. Here is the workflow that it seems should work:
However, it shows the popup all the time, even when all the relevant fields are filled in. In an effort to troubleshoot this, I created a field which simply shows all the dates and style names, and I can see that there is data that is populated. So when I make it list all the actual fields, here is what I get:
Formula:
Output:
But, if I change this troubleshooting field, to look for empty cells (by counting items on the list with empty dates and styles) here is what I get (please note there are 5 tasting events in this sample:
Formula:
Output:
So why is it counting all these fields as empty when they clearly aren’t? Is there a better way for me to conditionally format this popup?
Thanks in advance for any help!
