Help with popup
Hi, I have a repeating group. In this repeating group there is a button. When you click on a button it shows a popup. In this popup there is another button. When you click on the button in the popup, I want to update the current cell of the repeating group, so the cell in which the first button is.
The issue is that it’s not possible, because there is no data sent to the popup. Does somebody know how to do that?
Best wishes
Jakob
Hi there, @Jakob1… in the workflow for the button that shows the popup, use the Display data action to display the current cell’s thing in the popup, and you should be good to go.
Best…
Mike
Thank you very much :smiley:
