Greetings, I need help with the Stripe configuration.
I want to do the first tests to be able to charge from my ap.
I have included Stripe keys in my app but it gives me this message
Hey @graficosmorales
It looks like you might be using a customer from your test version in your live version. Did you copy your database from test to live? Make sure that you create your customer in live and have the live keys in the right place. Otherwise you will be using test keys in live, which wouldn’t be good either.
Want to share some of your workflows so we can see how you have things set up? Might be easier to troubleshoot that way.
