jayy
September 23, 2021, 4:46pm
1
I want 2 sides - left and right - of different background colors.
Each side is a group.
The problem is the height of the content in each group is variable.
Sometimes the left side is longer, sometimes the right side is longer.
This is what I get when the left side’s content comes up shorter:
This is what I get when the right side’s content comes up shorter:
This is what i want - the colors should fill up each side and be of equal length (the longer length of either side’s content):
Hope i’m making sense here…
nfisher
September 23, 2021, 4:49pm
2
Looks like you are using 1 element on the left and the background on the right.
You need to either use 2 elements, or use an image.
jayy
September 23, 2021, 4:56pm
3
Hey, I’ve edited my images to make it clearer.
I am using 2 elements - one on each side.
Perhaps a repeating background image might work. But it wont be responsive - it will fail on mobile - so the image needs to change on mobile (maybe). On mobile, the red section should stack on top of the blue section.
