I manage to make a text generator app
but I keep appending the initial inputs on the rich text editor also
please watch the 44 sec short video below
https://screencast-o-matic.com/watch/cri3f6ViysN
please I need some help to figure this out
Hi @rcdcanlas ,
You should create new custom state with text datatype and set initial input for the rich text editor.
For the each change of text and submitting the button, you should replace the custom state. it can works.
thank you for the response @testingwebdev2016
I already have a state which is a text data type which is this
Is this correct? or should I make another one?
how can I replace the custom state please? Can you please help me?
This is the workflow of my submit button
I think, append is adding altered text to the custom event, it will not replace the existing value. this was the problem.
So, try to remove append.
Just add like “Result of step 1 choices:first items text : find & replace”.
@testingwebdev2016
like this one? Am I doing it correct?
Yes, try this.
If you still getting issue then, please share app details to my PM. let me check this issue.
The problem is its removing my initial inputs. I was looking for someting write continues where it lefts off.
okay I will pm you
