Hey. Could you explain plz if I set custom state as dynamic text how does it work with different users if they do some actions that changed custom state’ value at the same time?
Hi there, @zelftb… the short answer is a custom state’s value is specific to the current user (or, more accurately, the user’s client/browser). So, no, multiple users would not be changing the same custom state’s value at the same time.
Best…
Mike
Also important to note that state will reset upon every page refresh.
Cool. Thanx, man!
Yep! Ok!
Slight correction. Custom state is at the client (browser level). It is not specific to a user. If same user opens the same url in different tabs or in different browser, custom state in that tab would be specific to the value in that particular tab.
