Hi all
I am trying to create a barcode and to print it in just a click of a button. I am sure many other people are aiming to solve the same issue. And i assume that a Plugin, especially made for this need, would find much appreciation! To all you contributors & Plugin makers… eg. @vini_brito
Current steps that i try to get this thing working:
- create Barcode (with Plugin)
- generate a PDF with that Barcode in it (with Plugin)
- Print the Barcode/PDF (with Plugin & API Print Solution)
More in details:
1. create Barcode
Currently i am trying to create barcodes with the great plugin “Barcode & QR Code Generator” made by @nicholasrbarrow
The problem for me is that this Plugin only generates SVGs.
2. generate a PDF with that Barcode in it
I am using the wonderful Plugin “PDF Conjurer” made by @vini_brito. The Plugin works great. But i am not able to inut a SVG. Only images such as JPGs or PNGs are supported.
3. Print the Barcode/PDF
The Plugin “PrintNode - Remote Printing” by @maru works easy and is fast in setting up.
PrintNode is not very expensive but very reliable as i know. But unfortuatelly it only supports PDF or RAW printing.
Thats why i try to create a PDF with the Barcode on it.
If anyone out there has experience with RAW printing on a Dymo LabelWriter 450, then please let me know
I have no idea how to set this up…
I tried the “SVG Coverter”-Plugin by @ZeroqodeSupport to convert the SVG to PNG or JPEG. But unfortunately that is not working, because the SVG that i generated by the “Barcode & QR Code Generator”-Plugin provides a Link that i save in my DB.
The “SVG Coverter”-Plugin can only convert SVG-Code that is inside the html (like the Chart Element as iin the example of ZQ). At least this is how i understand it. Please correct me.
Has anyone experience or issues the same problems?
Then i am inviting you to share your thoughts and solutions with others in this Thread
