How to display data through a system of approval status?
Hello
I would like to know how to make a repeating group (Let’s call it Final repeating group) that display some data coming from a previous repeating group (1st repeating group).
The 1st repeating group displays the data that the user enter in the imput location.
I would like to manage this with a system of approval status so that only the “approved data” are displayed in the final repeating group, but i am having troubles making it.
Thanks for the help.
Vincent
How does the data get approved ?
You could set a field for the data.
Field: Approval Type: Yes or No
Then do a search for with a constraint “x approval = yes”
Then when data is entered it can be given that value.
Thanks for the answer
As a beginner i still don’t know exactly how to proceed.
I will follow what Bardluffy recommend.
Do you agree with him ?
Yes, I was wondering what the mechanism for approvals was. As bradluffy says, you can add a field and set it in your workflow and filter.
That wojld make sense if this data is on seperate pages.
It works perfectly.
Thanks a lot for the help.
