I’m using a calendar plugin which you can click-drag on the calendar to create events etc.
The plugin has a workflow to move an element to an X/Y position, but it doesn’t work with bubble’s Focus Group element because the element itself is required to be tied to another element.
I also can’t use the settings in the Focus Group to move it to where I am creating events, because the events showing on the calendar aren’t elements themselves.
Regardless, I’d like the same behaviour of hiding a group when you click off. Is it possible to do with a “normal” group element? I’ve been scratching my head for a while trying to figure it out.
Thanks
