How To Reset Air Date Picker (Clear Dates) Inside of a Repeating Group?
Is there a trick or a workaround to resetting the Air Date/time picker by @seanhoots when it’s inside of a repeating group and clear all of the selected dates?
Hey @JustinC
Does the element action “Reset a Air Date/Time Picker” not work?
Yeah i found it, thanks!
That actually does not work.
I tried to ‘reset’ the Air Date picker inside of the repeating group when the repeating group became visible again but you can’t reference the Air Date / Time picker inside of it:
Any other ideas from anyone?
Try the Antena Plugin from @vini_brito
Hi! Thanks for the recommendation (:
In time, the plugin is actually named Orchestra.
Hi @JustinC
Did you manage to resolve this, i’m having the same issue?
Thanks
John
