How to set Default value in Multidropdown Element
Hi guys
I am facing an issue setting up the Default value in Multidropdown Which have an object of lists, that is giving the error while initializing
I am not able to add Parent data in Default value field of Multidropdown element.
Is there any solution for it or any alternative to solve this issue?
Issue
@bubblers Please help me! :pray:
The default value must be a list of ‘Skill Companies Companies’…
The fact that the expression is red means what you’re entering is not a list of Skill Companies Companies…
The Issue Checker will tell you exactly what the issue is, so check that first.
Without seeing your database structure it’s impossible for anyone to diagnose the issue (aside from you)… so feel free to share some screenshots if you still can’t figure it out.
