How to sort posts by upvotes?
Hi, this is a productlist app and here I want to create an experience that will sort the higher upvote posts to first but I can’t do it becuase I’m using upvotes data type is users not an numbers, So please help me to solve this feature.
Website link : https://productlist.app/detail_page/1659275913372x385422206075278800
Thanks,
The simplest (and most performant) way to do this will just be to create a number field on the Post datatype to store the number of upvotes…
If you’re doing it retrospectively you’ll need to run a backend workflow to set the vote counts…
Then, in the future, just update it anytime a new upvote is made.
