I am having an issue with customizing map maker icons (solved!)
Hello,
I am new to bubble and have been trying to solve a simple problem but i keep failing.
I want users to select the type of icon they want to be displayed as with two specific options and i have read some other similar solved questions however, when i make the map markers data dependent, the icon sections says no available icon even though believe i saved saved it in the database unless i saved it wrongly. here are the screenshots.
kindly help me out
Thank you
The type of markers are users location and the icons you are trying to access are on another DB type. Have those fields on the same DB type as your map.
Thank you for the reply. i understand it now better.
