Hi, I know I keep asking the same question on here but I really need help on this and I have yet to have a reply either on here or through the ‘contact us’ function. I can not progress until I have learned how to do this part. I have read and searched through the help pages and academy but I would be very grateful if someone could point me directly to the info I need if possible as I have either overlooked it or what I am trying is not possible (more likely I have overlooked it).
Hi, I have got to the point where I can click on a database (materials) item that is showing in a repeating group and have that data push trough to a pop-up for me to edit. The edit pop-up loads the date in to several inputs in the pop-up, of which 3 are drop-down menus.
I can get the data into the drop down menu (eventually) and all displays as expected. The problem I am now struggling with is now when I select the drop down menu to choose a different option it is showing me all the items in the ‘materials database > suppliers name’. Which is where it fetched the data from. If I want to update the supplier I need the dropdown to point to the ‘Suppliers’ database, ‘Name’ field.
If I Change it to look in the Suppliers database for the new value then it doesn’t push the date from the materials database when you initially press edit.
Any ideas what I need to do? Thanks Gavin
