I need help with templates
Can someone tell me if I can buy and use a zeroqode template if I’m using the free version of bubble? Or do I need to be in a paid plan to buy and use a template?
You’ll want to be on a paid plan eventually most likely. But you don’t Have to be
thanks! Another thing, when I try to buy a template from zeroqode, it says that is free, even tho is 249. Do you know something about it?
Hey Levon here from Zeroqode
which template you trying to buy?
Levon Terteryan
Founder @ Zeroqode
#1 Bubble Publisher and Developer
logo-icon-S-circle
100+ Bubble Templates
25+ Bubble Courses
250+ Bubble Plugins
20+ Bubble Building Blocks
Convert Web to iOS & Android
No-code Development Services
Zero Code Conference Replay - watch all the no-code industry leaders share their expertise and insights on building and scaling startups without code
hi, I’m trying to buy the udemy template, but when I press to buy, it says that is free and that now I have it in my tamplates. Then, when I check my tamplates, it’s not there.
Strange
I’d suggest you to record a loom screencast (loom.com) and send it to Bubble support at support@bubble.io
They should be able to help you out with this
