I will pay for help - phone support
My google maps is not showing up, i have made the api keys under my paid google suite account, i have even unrestricted them to test out if it was a key issue. still my maps aren’t showing up.
I will also pay for someone to help me create a function for my app to where i can push a button, and my ipad location autofill’s a form with the actual address of where my location is.
So the google maps just isn’t showing up at all? Are you using any type of domain services or just using it through the bubble domain?
Maybe you can schedule a meeting with @J805? He’s knowledge with Bubble :blush:
Make sure you have added a credit card to your google admin account. Maps won’t show up otherwise since Google changed this. I have found that it can take a little while for the maps to start showing up after you’ve added a payment as well.
Here’s a good step by step.
https://developers.google.com/maps/gmp-get-started
Edit. Missed that you wrote, “paid”. so assuming that you have already set up billing and added a card? If so… ignore me :slight_smile:
thanks for the help lol it works now, however i have an even bigger issue at hand =D
I need to load over 2 million lines of data from google sheets into google maps
