Searching on Bubble apps is generally a pain, you have to pay a fortune on Algolia or use a precarious native system.
If you opt for Algolia, you need to be on one of the more expensive plans or build your own integration with (paid) plugins.
By opting for the native system, you can only search one field, which is very sensitive (that is, you need to search a lot like the field).
Whiser Search is here to put an end to all these problems, in simple steps:
- Import your data;
- Place the element on your page;
- Update the data using the Plugin;
It’s easy, fast, intuitive and best of all: cheap. With Whiser Search you can (1) respect your app’s privacy policies and (2) speed up your searches.
Try it now at: searchapp.whiser.com.br
And access our documentation: docs.search.whiser.com.br
If you have any problems, don’t hesitate to send a DM here or contact support.
Thanks for building this!
Does it support auto-correct and case insensitive?
You’re very welcome! I’m glad you find this helpful.
To answer your questions, while I don’t support auto-correct, I do indeed support case insensitivity. If you have any more questions or need assistance with anything else, feel free to ask!
Cool, that works!
Do you have autocorrect somewhere in the road map?
I’m glad to hear you think it’s cool!
Auto-correct is indeed a complex feature, and it’s on our road map for future developments. While it may take some time to implement, it’s something we’re actively considering for the future.
got a few questions here:
why can’t i view the plugin page
where’s your example editor
how do users manage facets/searcheable fields/sorting/ordering/prioritzing
how can i filter results
where is your demo page, the link above only leads to a signup page
the docs are super sparse which led to these questions
Hello! I’m glad you’re interested!
Regarding the plugin page, I also don’t understand why it isn’t visible.
It is difficult to display an example editor, as the data may be sensitive, but you can access the demo editor at any time to see how you should configure the search using this link: whiser-search-demos | Bubble Editor.
Searchable fields etc. can be managed by the panel at https://searchapp.whiser.com.br/dashboard, as well as ordering and prioritizing (update scheduled for next week).
A real demonstration page is our bookstore (in Brazil, called Whiser) uses Whiser Search to make it possible to search over 175 thousand books in Bubble Things. Unfortunately, I can’t grant editor access, but you can see a public version here: Busca | Whiser.
Thank you for reading the documentation and giving this feedback, it is very important to us!
