Is it possible to build a webmail with Bubble?
I wanted to build a functionality for my users so that they can receive email. Is this possible with Bubble?
Eg.
When they signup at mybusinesss.com with their email,
[email protected]
it automatically creates an account with an email address,
[email protected]
This allows the user to receive emails at this address. They have to access mybusiness.com to see their webmail.
Thanks for the help
Manuel
I don’t think that this is possible. You would need a connection to your mail server and I doubt that they provide an API.
This is possible, but it would require you to either setup and run the email infrastructure or figure out a 3rd party provider that you could integrate with. I have also been thinking about this and looking for options. One that I’ve come across is Zoho Mail. It seems like a pretty good solution and not too expensive ($1 per user).
Thanks for the reply. Now that I have an example I will look for similar examples. Thats good news for bubble users.
Regards
