Is it possible to use my own DB?(not ise bubble DB)
Is it possible to use my own DB?(not use bubble DB)
when user input user’s info and click SAVE button ,so I set save button work flow like
I am trying to send user’s data to s3 I created and save it. Can I connect to my DB using axios or fetch? or using API call or Javascript code
how can I send when user’s data to my own DB not bubble’s DB
how could i do it? plz help me guys
There’s lots of ways you can do this depending on how you have your database setup. I use API calls and backend workflows. You need to capture a foreign key and link that to any data you store on Bubble (you might keep user login details on bubble since its native for example.)
Have a look in the forums searching on your specific requirements and you’ll probably find someone has done it.
I’m sorry could you show me any image how to set simply example.
Hey There - this isn’t something you can easily setup with 1 or 2 examples. Whats the reason you want to create your own database? What sort of database is it? S3 isn’t a database itself, its file storage.
If you are unsure of these things it might be better to use the Bubble Database to get started.
