Issue uploading files larger than 50 MBs
I am developing a plugin that is for uploading multiple files but the issue that I am having is that I am using context.uploadcontent and it is giving me an error (I have shared an image). I also want to mention that I have tried bubble default multi file uploader and it also gives an error when a file larger that 50 MBs is uploaded. Is there some thing that I am doing wrong or is it just a platform limitation.
I am also not able to find enough documentation on the upload file function.
Just to double-check: is this checked?
Yes, it is checked.
That’s the legacy method, and as you’ve discovered, it’s limited to 50MB. The new method which supports large files is called uploadFile(), and it’s located on the instance object - not the context object. You should see it after enabling it as @rico.trevisan has shown.
really appreciate it. it is what i needed. it is working but I think bubble has not provided enough documentation for this.
