Hello, I am trying to use Math.js, but can’t work it out even after reading through the topics in the forum …
what do I have to change?
I think your field is not set to Number?
sorry not sure I understand? I want it to be a number - how do I set it to Number?
When you created the field did you specify Number instead of text?
If that fails this may be an issue if memory serves I’ve come across because Bubble expects the MathjsAPI to return a Text value not Number which is really noting.
Try using the calculator element in the Components plugin. This also uses MathJS but it’s worth a try to see if Bubble handles it differently.
