Multi Dropdown and Repeating group
Hi all !
I need help on integrating my repeating group with a dropdown.
my problem :
I would like to have a line with test then another line with test2
my cfg :
Does your Multidropdown has a “value list”?
Something like this:
Multidropdown A's Value list
hi @rpetribu !
I do not have the list in the choice
No no… you are clicking after you should…
Click just after the Multidropdown A, as showned here:
like this :
Capture d’écran du 2021-05-20 18-23-10
Ok…
I think it may work…
The text in your RG wor should be something like this…
Multidropdown A's value :Item: # Current cell's index
I don’t think so because he expects a number :
Capture d’écran du 2021-05-20 19-07-11
You need to use Current cell's index
You are using Current cell's Active's non.....
ok it works.
Thx.
