Need help building a map feature
Hi everyone,
I’m wondering if anyone has experience creating a search function similar to booking.com’s map search. Specifically, I’m interested in a feature where dragging the map updates the results displayed in a repeating group on the left-hand side, and only shows the pins on the map within that particular area.
If you’re able to support please contact me.
Thanks
I can work on this. If you want , we can further discuss this in DM
DM’ed you
Hello,
I will be glad to assist you, kindly check PM.
thanks
Scott
