Need Help Designing and Building an Event Floorplan Feature
Hi all,
I’m building an MVP of an event management app that allows traders or exhibitors to book a ‘space’ at an outdoor event or expo and need help building a floorplan/map feature.
I’ve completed much of the MVP build but now I’m looking for someone help me come up with a solution and build the part of the app that allows organisers to create a map/floorplan of their event with specific spaces on it for the traders and exhibitors attending the event to book onto; similar to when you book a seat at the cinema.
An example of something I want to build is like this: Orion Entertainment – Demo – Seattle Convention Center – Expo Floor Plan by ExpoFP (although a simpler version)
I’m very open to ideas and options and I have funding to pay for dev time to help me build this feature.
Some options I’ve been considering are:
  • Allow organisers using my app to create their own floorplan using other software such as AutoCad and upload the image to my app. The i’ll use something like Image Annotation Plugin for Bubble | Zeroqode to allow the organisers to place the traders they have booked onto the map.
  • Alternatively I’m happy to integrate my bubble app with other software that allows users to build floorplan within my app, something like Getting started (readme.io)
Please private message me if you are interested so we can discuss the solution you’d suggest and quotes.
Thanks,
Phill
Seem they are using https://floorplanjs.org/ (probably the old version before they more to the new smplrspace stuff)
Seats.io is also a good solution that could work for your case. I’ve ready built an integration for this one. But both are possible to integrate to Bubble.
Best is to build a custom plugin for that
Hi @Jici , amazing stuff! I really like the look of seats.io.
As part of your integration did you build a custom plugin?
thanks,
Phill
I will send you a DM
Hey @phill.dev,
I can help you with this requirement, if it is still open.
Let’s connect on discord (himanshu_83987) to discuss further.
Hi @phill.dev,
I am an experinced bubble developer and am available to work on the MVP you are building. I am available to discuss it further over a chat. Please let me know you availability. Thanks
Think it’s time for you to add a Forum hero cape.
cape
