Hi Everyone,
I am wondering how others would go about building an interactive floor plan in Bubble?
I have a requirement for my users to select and edit locations of spaces/seats on a floorplan and I’m not sure how best to go about it.
My current best solution is to get my users to upload a floorplan image and then use the ZeroQode Annotation plguin to pin drop and save locations on that floor plan.
Any thoughts?
I’m needing to build exactly the same feature. I don’t suppose you manage to solve your interactive floor plan feature.?
I built a private plugin for seats.io, let me know if you’d like me to share it.
Thanks
Phill
Hey there Phil.
I would really appreciate that I’m actually struggling with this right now.
I’m trying to build a startup around safety in surgery. (Healthcare)
All I’m trying to do at the moment is load in an image and surgeons can click on the image where they can add a little bit of information.
I know it sounds crazy but doing this would reduce failure rates in surgery. As when doctors go from surgical ward to surgical ward information gets lost and therefore we harm a lot of patients quite often with catastrophic outcomes.
Is that something which you’re plugging would achieve?
Kind regards
