Noob to Bubble. Plan to build application with multiple Apis of flights hotels activities, transfers, trains etc. 100k + users w 10k concurrent users, is it scalable and would bubble be the right choice?
Hi there, @narayan… the answer is yes with a big ol’ side of it depends on how you build it. Someone would almost certainly point you to this resource…
… and I think this blog post might be of interest to you.
Hope this helps.
Best…
Mike
Thanks Mike, that would be helpful
No problem at all, @narayan. For what it’s worth, I think you should definitely give Bubble a go… you really have nothing to lose.
Being non technical, the learning curve would be pretty high but am ready for it!
