The other thing, i noticed that once i click on my notifications group the notification clears away. I want it to remain visible for feature references how do i set up?
thanks
You’ll need to provide more information for the community to be able to assist you. What’s your data structure? Screenshots would be especially helpful.
they are all going away because youre most likely adding read=yes value to the list of notifications once opened/visible.
Remove that workflow, have a clear all button that will add the read=yes value to the list.
And separate clear buttons for each cell that will modify parent group/current cells notification to read=yes
Or when the notification is clicked, presumably page will navigate somewhere, you can add the read=yes value in this workflow.
good job
They clear away still…
