Need help to track hours worked using tool
I am trying to build an online tool that tracks hours worked per week and generate weekly payroll report. For reference, I exactly want to develop like this: https://time-card-calculator.net
I have made the scratch, but some functions are not working as expected.
Can anyone here who can help me build a work hours tracking tool?
Any help will be appreciated.
Hey! @Kiranfromuk Totally doable in Bubble :+1:
At a high level, you’ll want to store each clock-in / clock-out as a record, then calculate daily totals and roll those up into a weekly total. Most issues with tools like this usually come from date/time math and grouping by week, not the UI itself.
If you share which parts aren’t behaving as expected (time calculations, weekly totals, overtime, exporting the report, etc.), it’ll be much easier to point you in the right direction or suggest the cleanest Bubble setup.
