kevin4
1
I’ve implemented it in Javascript, it works.
I’ve implemented it in Postman, it works.
In Bubble, it doesn’t work.
Image 1 shows it working in Postman.
Image 2 shows the configuration in Bubble.
Image 3 shows it not working in Bubble.
Has anyone had a similar experience? If so, how did you solve it?
kevin4
3
@NigelG Did what you showed me work for you? When I do that, I see this:
NigelG
4
Yup. Set up a Sharecount account and it worked.
Try deleting the whole API call and setting a new one up. Sometimes it gets confused !
kevin4
5
Thank you! Thank you! Thank you!
I deleted the entire call, and rebuilt it exactly the way you did, and it now works!
