I’m so close to achieving what I need to do (concatenating two lists and keeping duplicates) using the amazing List Shifter but for one issue that I can’t get round.
My ListShifter is inside a Repeating Group.
It works well but I need to run a custom workflow so that my list generates as the page is loaded. With essential help from Keith on here, I can see how it’s done but my issue is that when I create the Custom Workflow, I can’t select my ListShifter because it’s inside the Repeating Group and bubble can’t “see” it so the Element dropdown is empty.
If I move it out of the repeating group then I can select the ListShifter but, in turn, the list shifter can’t “see” the Repeating Group contents that it needs to display.
What do I do here? I feel it’s really simple. I’m not that confident with bubble and I feel like I’m at the outer edge of my “ability envelope” so if someone can help me out, I’d really appreciate it.
