New responsive engine - need help / I will pay for the task
I am having some issues with the new responsive engine and I cannot figure out a solution. I cannot get rid of the white space in the right side:
Please check below:
2022-06-06 12.59.55
may i look at your editor?
Check the minimum width of all the elements on the page. Had the same issue before because an element having a larger than mobile minimum width.
:point_up_2:this is probably the issue….
yes, that was the issue. Thank you
