Oauth 400 error - need help fixing settings
I cant a really big problem on my side.
I had my oauth running with battlenet from blizzard. Does someone have experience with oauth and can check if my settings are correct?
I am getting the following error: " Ungültiger Authorisierungscode oder Umleitungs-URL ist nicht gültig." - “Invalid authorization code or redirection URL is not valid.”
The setup is as follows:
The call is made from the following URL:
https://website.com/version-test?debug_mode=true
The re-direct url is
I got the correct API key and secret.
This is the network response:
Request URL:https://eu.battle.net/oauth/authorize?client_id=cypxrynb3v36peas3ezward85ymueredirect_uri=https%3A%2F%2Fwebsite.com%2Fversion-test%3Fdebug_mode%3Dtrue&response_type=code&state={"debug_mode"%3A"true"%2C"oauth_provider"%3A"apiconnector2-bTHqn"%2C"resume_key"%3A"1500741894150x1453"%2C"used_redirect_url"%3A"https%3A%2F%2Fwebsite.com%2Fversion-test%3Fdebug_mode%3Dtrue"}
I really looking for help here.
Best
Carsten
