oAuth doesn't work ("temporary issue")
Hello everyone,
I want to implement an oAuth connexion to my Bubble App from OpenAI’s custom GPT.
But it doesn’t work. And when I want to access to a link like this : https://renegocee.fr/version-test/api/1.1/oauth/authorize?client_id=[CLIENT ID]&client_secret=[CLIENT SECRET], I have this issue : “Sorry, we currently have a temporary bug. We will fix it as soon as possible. Please try again later!”.
So, do you think it’s really a temporary issue or I am doing a mistake somewhere ?
Thanks for your help !
Hi Michel.
To be honest it is kinda hard to tell from the message itself. It may be indeed a temporary bug, but if I am to look over both Bubble’s Status and OpenAI’s Status pages, currently there are no issues detected.
If you’re still experiencing this issue, I would give it a try later and/or check again the API connection. Also sometimes it helps to create a new API integration in the API Connector on Bubble’s side.
Hope this helps.
