Hello everyone,
I would like to integrate a kind of OCR system to my app that would allow me to extract the validity date of my users’ IDs, but I don’t know if it’s possible on bubble, can someone guide me?
Thanks
Hello everyone,
Thanks
I used OCR years ago.
Basically you need to take a good quality image, then send it to an OCR API, and they will send you back what it thinks it found.
Often you will need regex to filter out a lot of stuff. For instance, a zero looks an awful lot like Oo0Q. An I can look a lot like ilL1!| .
I think you get the picture. It’s a lot of work, but works very well. There is no free native bubble way of doing it though.
Good luck!
