I don’t think custom states is the way to go for this scenario. I’d recommend you save the “whishlisted jobs” in the user data type and display the data accordingly.
Yes, I can use the way using the data type to transfer the information and set up two custom types in the page itself and in the header (reusable element).
But what I miss or don’t understand yet is the “missing trigger” that informs the header to get the changed (new) information from the data type.
Aaah I see. It should update automatically when you get changes on your DB. If not you can use the action “Display data in group” to change it’s value using the result from the previous step (where you updated your DB). Element clicked → Make changes to… → Display Data in group.
Make sure the group you’ want to display the data on is of the same type you want to pass along to avoid any errors.
I suggest dont use page load triger it use compute power and make you page load slower.
there are many wasy , you can use hidden group which are referencign the jobs and applicaiton and then you reference the group to respected place.
Or what i suggect, inside you user hvae a filed for each wishlist job whcih should be a list of job, so you can use count to see how many job this user have applied. and in side job have a field for applied which would be a list of user so you know how many user applied
just reference these point in your reuseable element that set, it will auto update
Used the parent group and did a “Search for JobWishlist:each item’s JobList:count” and used this parent group in the text element “Parent group’s number: formatted …”
yes. that simple, and also one thing we do a lot is , we create a hidden popup and inside it groups to use them as data container, and then we reference then in app many places.
if you ever get stuck ping me here or in linkedin , always happy to help.
