Please Read: Editor Issues
UPDATE:
Okay, the editor should be useable again. I’m not 100% sure everything is working as intended, so if something is still broken, please email support@bubble.is. If possible, please include step-by-step instructions on how to recreate the issue, to help us find and fix it faster.
Again, very sorry for the inconvenience. Hopefully the upshot of this will be a better, faster Bubble…
OLD:
As several of you have noticed, we’re having some issues with the Bubble editor right now. At the moment, saving is extremely slow (you’ll see the red “saving…” indicator for a long time after you are done making changes), and there might be flickering effects as elements temporarily disappear and re-appear.
We recommend only making emergency changes to your apps right now. I’ll keep this thread updated as we solve the issues. I’m very sorry for the inconvenience… we recently rolled out a big change to the way app storage works behind the scenes to enable more reliable performance when you run your apps, and some parts aren’t working correctly.
