Post Not Displaying in Repeating Group After Creation:
Hey there ! I’m working on a social platform where users can create posts, but I’m having trouble getting the new posts to display in the feed. Here’s what’s happening:
  • The Create a New Post workflow runs successfully (confirmed in the debugger).
  • The database saves the post with the correct Date and User, but the Text field remains empty.
  • In the Text field of the “Create a New Post” action, I don’t see an option to reference my Input Field where users type their posts. Instead, I see static text options only.
Here’s what I’ve checked:
  1. The repeating group’s data source is set to Do a Search for Posts sorted by date (descending).
  2. Privacy rules are configured to allow viewing posts.
  3. The input field is on the same page, but I don’t see its value in the workflow dropdown.
I need help with:
  • Ensuring the input field’s value is accessible in the workflow.
  • Troubleshooting why the Text field isn’t saving properly.
i don’t believe there’s a reason for the input not to appear in the workflow dropdown unless the input is inside a repeating group
I am new to Bubble so I am unsure of the platform however I do believe the input box is inside a repeating group.
Do you have an idea how I could diagnose and fix the problem?
could you send a screenshot of the input 's location, including the element tree?
