Problem exporting data
Is anyone else experiencing problems exporting data at the moment?
I’m trying to export a small amount of data from my database as a csv (200-300 records), which normally takes a few seconds, but for the past hour at least it’s not working at all.
It seems to get stuck around 60% (even after 30 minutes) and no matter how many times I cancel the export it still shows up as currently running export task (at 60%).
I’ve tried it multiple times and will different datatypes, all with the same issue.
I wondered if anyone else was having similar issues? Or have had before?
Maybe it’s just a busy time for the severs? or could it be a bug?
I’ve got an error too, but it concerns the email sending : Impossible to export my DB
