I want to create an app
After creating or login should be a public chat but the database is not allowing it
Could your describe your problem a little more?
Hmmmmm… what’s going on here?
I can’t build I mean I can’t drag and drop and I still don’t understand the database
I’d recommend watching the introduction videos to get started. In the library you can see an abundance of tips and tricks that will help you build your first application. Make sure you have a strong understanding of databases in general before you begin to build – it may get confusing at some points if you do not.
