Problem with group being stretched
i have a problem with a hidden group. when the group appears, the group’s height stretches to stretch the parent group’s height that it is contained within. how do i alleviate this?
Can you post a link to show what you’re describing? I’m not sure I understand/can visualize it, having a look would make it easier to check out.
i think i figured it out. if you have a group that is not fixed width but then have a group within that group, that is fixed width, it will stretch in height and stretch your screen. it might be an error in bubble, or it may just be by design.not sure. but i fixed it by un-selecting fixed width for all of the groups within the group.
