Hi everybody,
I have a problem with the repeating group fonctionnality. I start with bubble and i want to display all datas from users table.
I do this parameters :
But when I execute the application, only 1 data display.
Can you help me for display all the data ?
Thank you for your help.
Have a nice day.
Hi there, @frederic.chantelle… your issue is almost certainly related to the default privacy rule on the User data type. So, check that link and see if it helps.
Best…
Mike
Hi @mikeloc thank you for your reply. The issue was caused by the default privacy rule. I modified this rule and now i can see all informations in the table.
Tks a lot for your help
