Problems in safari
Hi there!
I have detected two problem when a bubble-app is used in safari. I think it should be fixed quickly. I’m a fan of Bubble and I think they should do something to fix it.
  1. The link element. The link element works when the user clicks, but it doesn’t work when the user hold down the element, it doesn’t show the user that is on a link element (i.e open in new tab is impossible).
  2. The input, when the type is ‘decimal’. It doesn’t work well (doesn’t allow the user to enter decimals).
The problems have been around for a long time, does anybody know if Bubble is working on them? Or just doesn’t care?
