Problems with app and plan
I payed for a personal plan.
I created and app, and after i removed as I wanted to start form scratch with Canvas.
Now, I cant use it as new app is not in personal plan, so what?
How can I use the plan i already payed?
Many thanks for your support.
Every app has it own plan, so you should either pay again or try to talk with support.
May thanks, I will contact support.
Just a UX/product recommendation. When a user “erase” the app , this should go to a trash with a recovery option.
Regards,
May be. But from our end it was not visible.
This is nice idea. Please add your idea into bubble ideaboard
@joseluis
In settings:
You can change the paid app to be a non-paid app by changing it to free.
And … change the new app to a paid plan :grinning:
Thanks, the problem lies in the fact that I remove the paid app without “release” it and now im blocked.
Some recommendation?
Reach out to Bubble support :grinning:
