Problems with Bubble's Rich Text Editor plugin
Hey guys,
I’m having a problem with Bubble’s Rich Text Editor plugin, so I’m posting here to see if anyone can help me.
After saving the record where I used the component, even when executing the Reset a Rich Text Input action, when I enter another record, if the user does not edit the field that has the component, it records the information from the previous record.
It’s as if it records the information in a “buffer” and if the field is not edited, it takes this information from the “buffer” and uses it to store it in the registry, even though I don’t edit anything!
Has anyone experienced this situation with this component and managed to resolve it?
That is a bug that has been known by Bubble for I think about 3 years or more now. I don’t recall it ever getting fixed, but perhaps, maybe, there is a chance, they had, and the bug crept back in. Maybe submit a bug report.
One thing to check is that your initial content is not set to a field that is getting changed by the element.
One thing to try is put it into a group and then instead of reset input, do a reset group data.
Hello @boston85719 ,
Thank you for the tip. It finally worked!!! Let’s wait and see if the bug will ever be resolved!
How did you manage to make it work? For me, all attempts to reset the RTE fail…
Try setting the data source to something other than the parent group’s data.
The RTE can retain old content if not edited. Reset its parent group or use a custom state to clear it.
It seems that this error happens when “Enable auto-biding on parent element’s thing” is checked. This is what I did to fix this issue on my end:
  1. Unchecked “Enable auto-biding on parent element’s thing”
  2. Set “Initial Content” to the column associated to the Rich Text value. In my case I set “Initial Content” to “Parent group’s Product’s Long Description”.
Once I unchecked the “Enable auto-biding on parent element’s thing” the “Reset a Rich Text Input” worked.
I hope you find this useful.
Best regards,
Conrado
The fix is to not use it’s parent group as a source. Point it to another element with the same datasource (or create one).
That’s how I’ve been getting around this issue for a while already
